Runner 172 question.
Discussion in 'Maxiscooter Tuning' started by nashas, Jun 12, 2009.
  1. nashas
    nashas New Member
    Hi, I had bought a runner 180 and made this setup :
    Malossi 172 , with selfmade piston (a copy of original , but has only 1 piston ring(on dyno +1hp))
    mazuchelli (smth like that) 54mm crank,
    malossi vario 13.5g rollers
    polini maxispeed cluch
    Technigas rs180 pipe,
    stock 20.5mm carb.
    so i can't reach more than 84mile/h
    and can't make a power wheelie.
    I would like to reach 100mile/h and make a power wheelie , what should I do ? any help?
  2. nashas
    nashas New Member
    I forgot to tell other problem, with stock filter runner goes nicely , with free inlet one it goes crazy on powerwheelie , but on 20m/h it loses all the power , and I cant pull ther throttle , if i do - it dies.
  3. Blue dwarf
    Blue dwarf New Member
    oooh my God :confused:cratch:
    Over to you Minor and company and good luck im off to Pod for the weekend :amen:
  4. LEE
    LEE Member
    i think i need stitches can we please make this a sticky so i can read it everytime i come on :lol:
  5. monty9120
    monty9120 Active Member
    Vespa gts300
    i think your lucky to get 80 ;)
  6. PrettyDodgyDave
    PrettyDodgyDave Member
    Runner 180
    you have a 180/172 with a bodged up piston that doesn' t powerwheely hmm?
  7. LEE
    LEE Member
  8. Runner-Joe
    Runner-Joe New Member
    Typh 125
    lol im amazed
  9. PrettyDodgyDave
    Runner 180
    lool was that aimed at me lee?
    whats it jetted to and did you change the jet when you put as filter on it ?
  10. nashas
    nashas New Member
    I had changed jet to 98 , it runned cool ,but it woun't start up after night... so I chaged it back., today I had reached 100mile/h. i had put a 36mm carb from my friends olr aprilia rs., I checked a speed with my r1 , and friends gsxr , the speed were 100m/h. , Icant do powerwheelie , but I can reach the high speed. what should I do?
  11. PrettyDodgyDave
    Runner 180
    i dunno then?
    them rollers seem light to me i dunno why it dont wheely
    what springs yyou have and how long the rollers been in there?
  12. Kieran
    Kieran Active Member
    st
    lol at 100mph clockspeed
  13. monty9120
    Vespa gts300
    my 180 used to do the clock in standard form lol.
  14. LEE
    LEE Member
    not aimed at ya just pointing it out
  15. MiNoR cOnFuSiOn
    this has got to be a wind up.......
    you have the ability to "make" a piston yet ask questions about carb setup in such a clueless manner... what is the piston from originally? im sure you dont have a forge in your garden....
  16. LEE
    LEE Member
    its probly chemical metal or summin the thesecond groove
  17. nashas
    nashas New Member
    I have original malossi piston, but that where I made myself, I used a nother piston 66mm diameter. I made a form simmilar to a original one , actually it looks same as original, only with one ring ;)
  18. LEE
    LEE Member
    :worthless:
  19. MiNoR cOnFuSiOn
    so 66mm diameter, wich is off a crosser more than likely.. so who rebored the cylinder for this bigger piston?
    thing i dont get is, you claim to have the mechanical/engineering ability to size/bore a cylinder yet cant tune a carb? me thinks this thread is some distant fantisy
  20. 2stroke-power
    2stroke-power Active Member
    on 1-wheel
    me thinks its just a waste off time to read this post ,without pics off piston ,1 bhp on dyno y didnt you set you carb up when you had it on the dyno
