rs125 engine
Discussion in 'Bike Chat' started by adam_nrg, Sep 9, 2007.
  1. adam_nrg
    adam_nrg New Member
    are the engines from all rs125 models the same?
    thanks
  2. Purplepill
    Purplepill Member
    No, not sure exactly whats different and on what years but they have different carbs and displacement
  3. tweak
    tweak Member
    Allow ROSSRS to answer this one shortly, but briefly Rotax 122 or 123 motors are used, both are equally as chocolatety :pimp:
  4. ROSSRS
    ROSSRS New Member
    chars mr tweak (only sent your v5 off this week, crashed scoot, been fucked :) ) rotax 123 used in the old shape bikes, 122 in rounder new shapes and 06 models. major difference between the two is the fact that the 123 has a cast iron bore and the 122 uses nicosil plated aluminium. the studs holding said bores are also different so top ends off a 123 will not fit a 122 without elongating the holes, unfortunately the 154cc big bore top end is designed for 123's, so need modding to fit the newer bikes. other difference is 122's have retarded ignition at 5500rpm for emission reasons, can be removed by cutting out a rectangle from the back of the cdi and snapping a small bridge of circuit. heads are the same on both. 123 runs coil ignition. 122 got a wank starter motor, 123 has a massive one that doesn't break. cases all seem identical, porting, gear ratios etc. early af1's used a 124.
  5. ROSSRS
    ROSSRS New Member
    and yeh, 123 has a vhsb 34 flat slide carb, 122 has phbh 28 round slide. vhsb and manifold fits straight on the 122 and is the only advantage over the 122.
  6. ROSSRS
    ROSSRS New Member
    oh, and slightly different mounting points. but nothing major.
  7. SpAnNeR
    SpAnNeR New Member
    how the fuck did you crash that tractor you fat cunt?
  8. ROSSRS
    ROSSRS New Member
    your mum was on the back mate, front wheel no where near the floor, couldn't steer. :p nah, car pulled out on me, gey.
  9. haugh
    haugh New Member
    lmfao
  10. PAUL V
    PAUL V New Member
