rounded variator nut
Discussion in 'The Workshop' started by charliegti, May 22, 2008.
  1. charliegti
    charliegti New Member
    just gone to fit my polini variator speed control to my speedfight and ive rounded the fuker off lol any suggestions on how to get it off ??!!
  2. Jefr0-180
    Jefr0-180 Active Member
    Rounded what off and what did you use?
    Thread title is only gonna piss people off btw so I'd change it
  3. charliegti
    i rounded the vaiator nut off that connexts to the crank
  4. Sw1fT
    Sw1fT Active Member
    200SX S13
    lol mate, not the swearing in the title, the fact that the title doesnt make any sense and doesnt tell anybody what the thread is about.
    change the thread title to "rounded variator nut" or something similar, as thats what you have done, you've rounded the nut that holds the variator on from the little info you have given, so you will need to get a file and file two flat sides onto the bolt, then use a locking tool and a decent fitting spanner.
  5. charliegti
    thanks mate will try that now
  6. fuff66
    fuff66 New Member
    Irwin sockets are good for rounded off nuts m8,they have a reverse spiral inside that bites on,they aint cheap though but bloody good,machine mart sell em but you might get em cheaper somewhere else
  7. wobbly_trials
    get a grinder with a grinding disc, not a cutting disc, grind new flats down to 17 or 15mm, then use a decent set of sockets.
  8. capri dave
    capri dave Active Member
    if it was a nut on anything else but the crank, i would of suggested banging on the next size down star shaped socket....
    but its a big no no hammering cranks, you can knock them out of alignment...
    so as swift and wobbly said really ;)
  9. baz172
    baz172 Member
    you could try a nut splitter think there about a fiver
  10. px166bajaj
    px166bajaj Active Member
    I was going to suggest that, but as it's the crank, I'd try the other suggested methods first if I were you.
  11. Biggie
    Biggie New Member
    get some sockets called turbo sockets
    have teeth that grip into the nut and comes off pice of piss..
  12. chris14
    chris14 New Member
    try using an imperial socket did it on a mates bike and worked perfectly then replaced nut wen it wos of
