rounded off bolt
Discussion in 'General Scooter Discussion' started by clumxD, Mar 18, 2011.
  1. clumxD
    clumxD New Member
    any advise how to get a 9 ml rounded iff bolt off my engine casing?
    advise appretiated cheerss
  2. petrolblue
    petrolblue New Member
    Try using plenty of penetrating oil and leaving overnight for starters, then you could try using a locking wrench such as mole grips or banging a smaller 8mm socket onto the head. Alternatively a company called Irwin make bolt extractors which are like a socket with reverse cut spiral blades so that as you try and undo the bolt the blades cut into the head and get a grip. It will totally ruin the head and you will need a new bolt but I guess it's already ruined if it's rounded anyway. The set I have only goes down to 10mm but they may do a smaller set I don't know. Try googling Irwin bolt extractors and see what comes up. Hope this helps and good luck mate :thumbsup:
  3. clumxD
    clumxD New Member
    ive tried mole grips :( okay mate ile have a look cheeeeeers !
  4. suzuki ay screamer
    suzuki ay screamer New Member
    use a dremmel and cut accross the top of the bolt thus making it a flathead.
  5. eddo241
    eddo241 Member
    NEOS
    take it to any ats for a £10 they got mine out
  6. Stig
    Stig Well-Known Member
    EXUP1000
    slot the head with dremmel & use flat blade screwdriver to turn out or cut head off leaving treads sticking out when case removed...then turn threads out with mole grips
