The rollers in my Zip SP are basically knackered. there square lmao. Could anyone recommended any for me? What weight and make? Links are appreciated Cheers.
It seems to pull of boggy though if you get what i mean?. And the mechanic at Midlands Scooters said its most likely that the rollers are not rounded as they should be, so he said buy some more and see if that helps, does that make sense to you? or do you believe it's something else?. Cheers.
i swear at the beggnining of the post you said there nearly square ...so go buy yourself some standard weight rollers then..
Ok ill go get some more, of the same weight. IF i can get the cover off, one of the bolts are seized.
