Rollers NEED HELP !!!!
Discussion in 'The Workshop' started by NRG_JON_92, Feb 17, 2009.
  1. NRG_JON_92
    NRG_JON_92 New Member
    Hi ive just fitted my stage6 pro replica exhaust ive been told to get some better rollers as my ped will only get its speed after 9-10k revs could anyone help me choose the right weight i was thinking around 5.5g :pimp:
    my ped is a NRG power air cooled
    (the ped is 100% standard exept for the exhaust and is still restricted!)
  2. kyle1b1
    would say about 6g maself
  3. NRG_JON_92
    hmmm
    i might get some 5.7G's
  4. CZYNRG
    CZYNRG New Member
    I'd go around 6g like Kyle advised, Dont go too light it will rev and go no where
  5. TyphModification
    TyphModification New Member
    Typhoon Gilera 70
    Fully Derestrict it and bung in 5.5 rollers, :cool:
  6. wobbly_trials
    buy yourself 4 sets, go 4.5 5 5.5 and 6
    get as close as you can then mix for optimum. say you end up using 3 5s and 3 5.5s then you know you need 5.25s
  7. Vesta
    Vesta New Member
    De restrict the ped first ffs.
    I've got a bike running the same engine spec in the garage with a sport rep, you will need to put harder clutch springs in, im running 4.7 gram rollers and it still feels sluggish not a good exhaust at all.
  8. NRG_JON_92
    im getting 5.5 + 6g's as a friend as advised as he has the same ped and with the same mod's
  9. Vesta
    Vesta New Member
    de restrict the cunt first.
  10. TyphModification
    Typhoon Gilera 70
    LOL YEAH X2 MAN GIVES U THAT EXTRA BIT OF SPEED AND DONT HAVE U SCREAMING AT 30
  11. CZYNRG
    CZYNRG New Member
    Sticking a pipe on a restricted bike is daft as pal, you'll get no difference in speed or anything, just take the variator washer out while your in there.
  12. Vesta
    Vesta New Member
    YEAH BTW TURN YOUR FUCKING CAPS OFF
  13. Jamie
    HOW THE FUCK DID YOU MANAGE TO BOOK TICKETS FOR PARIS FOR VALENTINES DAY WHEN YOU DONT KNOW HOW TO WORK A KEYBOARD
  14. TyphModification
    Typhoon Gilera 70
    Calm down forum bods, I forgot they where on. Sorry dont have a heart attack. :w00t:
  15. MiNoR cOnFuSiOn
    ewrm, need clutch springs... thas why it wont rev off the line :confused:
  16. NRG_JON_92
    i used to get 28 now i get 42
  17. CZYNRG
    CZYNRG New Member
    So 42 is enough? Strangling a engine is just terrible
  18. jon_w
    jon_w New Member
    Changing the exhaust is altering what RPM the bike makes its most power
    Therefore you need to change your rollers. I use 5.5gram with the giannelli reverse, but not every pipe is the same. Like you and others say though, 5-6 gram are around the area you need to aim for.
    Thing is not many people can tell you how the stage 6 pipe works on our peds. They could be easy to set up with rollers, could be difficult. You need to use some lighter rollers and tell us how they work out. I'd try 5.5gram
    Standard clutch springs suprisingly dont suffer with just a sports exhaust on the NRG powers .. u can use tighter ones so it engages at a higher rpm will help obviously
    Rollers and jetting are the two things you definately need to do with a new exhaust
  19. NRG_JON_92
    thanks jon ;)
  20. px166bajaj
    px166bajaj Active Member
    Too....many.....JONs.....old brain.......incapable......of distinguishing them!
