rollers and jetting
Discussion in 'The Workshop' started by NJH, Mar 3, 2008.
  1. NJH
    NJH New Member
    hi, sorry to ask, but couldnt really find anything definate on the search so.
    im soon going to 70cc my engine, as from what ive read on here it makes more of a difference than changing an exhaust etc first so, i think im going to go for the polini sport kit, as it looks like its got an edge on the malossi.
    i only have around £100 to spend, so i can only really afford the kit, and some rollers etc to match, so ill be running the standard 12mm carb.
    my friend has kindly gave me a viper exhaust (i know theyre not that good, but will be better than stock) which i have cleaned and painted.
    just wondering what kind of jets i need to order, if standard is 72. ive seen around 8-12% for the 70? but what about an exhaust aswell?
    and also any ideas on roller weights, i know standard is 6.5g but thats obviously far to heavy, as i put some 5.0g's in and it was a lot better, but would i go lighter or heavier for the 70? i know its usually lighter for an exhaust
    sorry to be a bother.
    iits a minerelli horizontal a/c by the way.
    thanks guys
  2. Jamie
    hi, i would say some nice light 5g rollers should make it rev nicely.
    yes 8-10 percent for a 70 kit and about 5 percent for the exhaust ;)
    i would work it out for you but i dont have a calculator and im shit at maths
  3. NJH
    NJH New Member
    okay thanks a lot mate, and thanks for the fast reply.
    will 5g's be appropriate, i was thinking of buying two sets, so would i buy lighter or heavier to the 5's ?
    okay then so if i order 5 jets, id proberly oder about 13% 14% 15% 16% 17%, for the increase?
    and is a standard belt thats done about 300miles okay to use with the 70?
    many thanks
  4. NJH
    NJH New Member
    hmm, and 18% increase is an 85, sunds abut right as ive seen a lot of people running 86, or am i completely wrong?
    also how much will i have to stiffen my clutch springs, i see the sets come in +15% +50% and +75% ??
  5. Biggie
    Biggie New Member
    Your standard belt is ok and i'd go for the 15% stiffer clutch springs..maybe the 50%.
    If the standard jet size is 72 then get around 92 and downwards..better to be safe(running rich) then sorry..
  6. NJH
    NJH New Member
    ok, is 1 jet size much different?
    eg, would i buy 92 91 90 89 88 8786 85 84 83 etc
    or
    92 90 88 86 84 ?
  7. NJH
    NJH New Member
    when you do the jettin, by plug chop or whatever. does it make a difference as its not run in :confused:
