Roller Change
Discussion in 'The Workshop' started by Jasemc, May 24, 2008.
  1. Jasemc
    Jasemc New Member
    Hi, i changed my rollers this morning from the stock 13g ones to some 10g ones. Bearing in mind the bike is 100% stock b4 this change.
    I expected a little to much i think because the acceleration is hard to judge. I cant tell if its improved. Mainly because of the question im going to ask.
    When others have changed their rollers. Has the sound of your bike changed?. My bike sounds a lot different. A bit beefier.
    I think im going to change them to somewhere in between the 10g and the stock 13g cus the loss of top speed is mad!
    Cheers
    Jase
  2. Jasemc
    Jasemc New Member
    I know that down side of the light rollers is the loss of top speed.
    Up side been the "better acceleration" + The beefy Noise.
    But am i right in thinking im going to lose out on MPG? i guess the engine is still reving to the same limit but only getin 80% of the orignal speed.
    Might try and live with it and see if i like them.
    There the Dr Pulley oddly shape ones.
  3. alex_1966
    alex_1966 New Member
    heavy rollers wont give you more topspeed because the gearing is still the same, theres always a optimum roller weight wich will give good acceleration and wont reduce topspeed
    a 3g drop does sound excessive for a stokc setup, maybe go for 12's or mix the 10's and 13's together to make 11.5
  4. Jasemc
    Jasemc New Member
    ok cheers.
    And the noise. I think while i took the tranny cover off, (had to take the air box off a little too) i Knocked the air intake to the carb out. so its getin a little to much are, makeing that noise and bogging a little bit at the higher revs. Ill check it out 2moro.
    :D
