revving - doesnt pull off
Discussion in 'The Workshop' started by JoeLangton93, Jul 14, 2009.
  1. JoeLangton93
    JoeLangton93 New Member
    Speedfight 70
    got a speedfight 2 (i no you all hate them, im starting too aswell)
    de restricted, malossi variator, gianelli reverse, malossi air sponge (standard air box).
    baiscally fitted all the parts and now, starts fine, revs fine, but it doesnt fucking move anywhere (only on full throttle extremly slowly).
    looked through alot of posts about similar incidents but most were solved from rollers being put in wrong ect. but i no it is not this as i have taken the variator apart and checked them about 3 times now. also wont be the clutch as it was fine before i put on all the parts and i havnt fiddled with it at all.
    if anyone has any ideas i would be very gratefull
    thanks very much
  2. m1ck_t
    m1ck_t Moderator Staff Member
    alot of shit
    Re: revving - doesn't pull off
    roller weight wrong, and upjet
  3. MiNoR cOnFuSiOn
    rollers are too heavy.
    all revs and no movement = rollers too light
    no rpm and slow= rollers too heavy
    find the happy medium
  4. JoeLangton93
    Speedfight 70
    thanks very much ill try it tonight
    also is there any chance it could also be that the belts too tight - even though it is a belt which deifnatly fits my bike, it seems really tight.
    i have malossi vari but stock clutch?
  5. m1ck_t
    alot of shit
    you fitted the belt wrong, open up the the rear pulley completely, alot of people just pull it open wich doesnt really work, i tend to pull and twist it to open fully then drop belt in, make sure theres enough slack in the belt when you tighten the front pulley half.
  6. JoeLangton93
    Speedfight 70
    roller weight adjusted.
    upjetted 6 sizes.
    and diffrent belt - now pulls off very nicely
    thankyou all very much for your help really appreciaited
