Revs up and down vx125
Discussion in 'The Workshop' started by 4strokerunner2005, Nov 2, 2011.
  1. 4strokerunner2005
    4strokerunner2005 Member
    gilera vxr200
    Up until recently my bike was running ok and i havent changed anything. Right now it starts and as it warms up it over revs to the point the back wheel turns, when stationary at lights u can feel the bike easing forward. When i turn the idle speed down (even by the smallest amount) it idles as if its about to cut out, only just ticking over by the sound of it. I have tried lots of things different auto choke, different jet, cleaned carb air filter checked for air leaks still not solved problem. Any ideas? I have tried 105, 108, and 110 jet and the problem remains? Oh and the rev cable is not caught anywhere it is free.
  2. Davey.Boy
    Davey.Boy Member
    Is it idling smoothly - ie revs don't go up and down randomly? I have had a similar problem with a VX125 which turned out to be a simple air leak?
  3. 4strokerunner2005
    gilera vxr200
    It idles smoothly at times, sometimes i pull up at lights and it idles normal, other times it over revs, tried turning it down and even the smallest amount makes it sound as if its going to cut out, where abouts was the air leak?
  4. Davey.Boy
    Davey.Boy Member
    It turned out to be a pinhole in the diaphram, just swapped it over and it ran perfectly.
