Revs full on idle and dies when throttle twisted
Discussion in 'The Workshop' started by TeZ258, Feb 3, 2012.
  1. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Hi all,
    Just recently bought a dellorto 21mm carb for the speedfight and it revs full on idle and when I touch the throttle it bogs.
    Any ideas what the problem is? I know it's something simple, just can't seem to work it out :/
  2. creamsodauk
    creamsodauk Ped Ped!!
    Runner 125 SP
    have you tired running it with the throtle cable unplugged incase its snagged and holding it open?
    as for the bogging, it sounds like mixture issues. Could be a case of a major air leak letting in too much air, cheack all the pipes and clamps are tight
  3. TeZ258
    TeZ258 Member
    Speedfight 50cc
    The throttle slide is at the bottom.
    There is a vacuum inlet on it that I haven't blocked. Could that be a problem and if it is, how do I block it?
  4. Sketchytom
    Sketchytom Roach
    Rally 50 you get me
    yes that would cause a problem if it is a vaccum feed
    you just put a 2 inch length of hose on it and then get a bolt a screw it in :D easy peasy
  5. creamsodauk
    Runner 125 SP
    as above, thats one big old air leak you have, pipe and a bolt will solve it, id persoanlly use a little selant on the bolt just to be 100% sure of no leaks as it will throw the jetting off
    Carl zip 2t 50 likes this.
  6. TeZ258
    TeZ258 Member
    Speedfight 50cc
    Ahhhh ok. Thanks guys. Will have a look when the battery's charged.
