would it be possible to fit the clocks from and nrg 50 with rev counter on to a typhoon 50 1997 model?
would it not just be a case of putting the clocks off an nrg on and wiring up rev counter.i just want a rev counter thats all as i hate not having one
u hate not having 1 theres not alot of mopeds with them the only good 1 with 1 os the nrg wot bikes do u normaly have then ??
my runner vx had one and my cbr had rev counters.i just like to see what revs im doing and to know im not stressin engine 2 much.just thought it would be a swap over and a bit of wiring as the nrg and typhoon are similar
you can hear if your stressing an enigne, plus once its setup it wont rev past where you want it too untill you reach the top of the gears... in wich case you will feel the revs start to climb. the nrg clocks take ALOT of rewiring to work wiht a typhoon loom, the nrg loom andf clocks plug STRAIGHT ino to a typhoon.... every part prittmuch (need to change one wire on the back light and skip 2 wires on the headlight) WAY the easier way to go if you did want a tacho...
