I have a Sym Jet 50 2002. Just put on a Technigas Next R Exhaust. Still goes as standard 35mph? Only difference is it gets the a hell of alot faster, but then it seems to not be able to push over 35.... Is there a restrictor washer i need to take out, or CDI???? What do i need to do to get it going 45-50 without buying a 70kit?
I checked, and the exhaust prior to fitting was de-restricted. And i havent checked that, as as told it may be in the clutch so didnt want to take it to bits untill i knew...
Hi, If your exhaust is de-restricted and you havent done the washer, then watch this: you should be going about 50 in no time Hope this helps
Hmm, i un bolted 9 screws that hold on the cover, went to slide it off, and nothing.... It is on there rock solid, theres like a rubber lip where it should pop out, but nothing?
