Removing stickers
Discussion in 'The Workshop' started by Aerox-lad, Feb 22, 2008.
  1. Aerox-lad
    Aerox-lad New Member
    hi there are 2 small rectangular stickers on my ped that i want to take off. is there any easy way of not leaving rectangular marks from where they had been? will white spirit do the job? or Wd40?
  2. SR-STEF
    SR-STEF New Member
    peel the sticker off and clean it with chain lube remover if u have any if not you can always use hot soapy water and elbo greese. unsure weither wd40 will work but it might
  3. ben690442
    ben690442 New Member
    i just used a hairdryer to melt sticker a bit then it all comes off piss
  4. rossmofo
    rossmofo New Member
    gilera Ice ZX7R
    petrol is good for removing any remaining backing glue as long as you wash it away relatively quickly afterwards.
  5. numanoid1704
    numanoid1704 New Member
    stickers
    hi,another old trick,peel off top of sticker then use nail varnish remover to get rid of glue left behind :D
  6. Aerox-lad
    will any of these chemicals actually strip the paint and glue?
  7. chris14
    chris14 New Member
    just use a hairdryer or hot air gun and if any sticky shite left just use a bit of thinners and shudnt mark the paint if your carefull you only need to use a little bit
  8. wobbly_trials
    exactly, hair drier is safest then lighter fluid, thinners, meths anything like that will remove the crap left behind
  9. Mehmet
    Mehmet Active Member
    AUDI A3
    :msn1:
    Just peal the fucker off then clean off the remains......
    how hard can it be :w00t:
  10. wobbly_trials
    after about year stickers (well proper vinyl ones) go hard and have to be heated or they just break up when you try to peel them.
  11. Mehmet
    AUDI A3
    But his aerox looks fairly new so i dont think he will have that problem i took of my dna stickers from a 04 plate with no problems :punk:
  12. Aerox-lad
    im just gonna leave them on there. theyre 'poole racing' ones. as the bike was in poole when i bought it.
