Removing stickers
Discussion in 'General Scooter Discussion' started by NEMTIZZ, Sep 25, 2007.
  1. NEMTIZZ
    NEMTIZZ New Member
    Just received my NRG MC3, and am wanting to remove some stickers, what would be the best method?
  2. Jamie
    hammer and chizel.... :p
    onli joking mate...... when i did it i used washing up liquid and hot hot hot water and a sponge. just rub the stickers down with the sponge covered in the washing up liquid and hold the sponge over the edges until the stickers go all soggy and rubbish...they should then just fall off ;)
  3. SMF_12
    SMF_12 New Member
    Or you can heat em up with a hairdryer and peel them off.
  4. jacksp
    jacksp New Member
    or, you can peel them off then use some stuff called 'sticky stuff remover' which is well good!
    and for cleaning my spokes aswel :w00t:
    iv heard wd40 helps aswel, but not sure lol :pimp:
  5. NEMTIZZ
    NEMTIZZ New Member
    Cheers lads <3
  6. gazell
    gazell Active Member
    hair dryers the best method i think
  7. Nrg-Sam
    Nrg-Sam Active Member
    well, if the stickers are hard to peel off, peel them off a bit, spray wd40 down the point where they meet the plastics, peel some more, spray some more then should come off easy
    depending on adeshive it may wipe off with a cloth and wd40, if not generally petrol gets it off easy as :cool: but it can be risky on canned sprayed surfaces tho...
  8. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    Hair dryer works the best, and instead of sticky stuff remover to get the sticky stuff off, use white spirit, every family has got sum lying round the shed somewhere :pimp:
  9. haugh
    haugh New Member
    Yeah thats what i used ;)
  10. NEMTIZZ
    NEMTIZZ New Member
    The WD40 worked a treat ;/
