Removing Stator Motor And Oil Pump?
Discussion in 'General Tuning' started by jamieg01274, Dec 15, 2011.
  1. jamieg01274
    jamieg01274 Member
    doing a engine rebuild on my ac zip if i remove the oil pump and startor as i will be running premix and no electric start will this cause problems eg the whole for the start motor needing blocking up or a plate to cover ? thankyou
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Nah it'll be fine just make sure when you remove the pump/bottle leave the sender plugged in or it will cause your dash board to flash (Not a full circuit) as for the electric start just remove it and unplug it. Wont cause any problems. You could black the hole for the Electric start but the hole's so small it don't really matter.
