removing snapped bolts from the engine
Discussion in 'The Workshop' started by robhall123, Jan 25, 2011.
  1. robhall123
    robhall123 New Member
    hey today i was changing over my gears on my aerox , i finished the job and was putting my oil bolt back in and it snapped on me :/ anyone know of a good way to get it removed without damaging the engine or the thread ?
  2. yellasei
    yellasei Member
    125 typhoon
    drill into it and hammer a torx bit into the drilling, that should enable you to turn and undo the bolt thread.
    you just have to make your own mind up on what size torx and drill to use. this is how i remove snapped bolts ;)
  3. robhall123
    by torx do you mean a torx screw driver or an bit for a screwdriver ? and its quite a this bolt :/
  4. yellasei
    yellasei Member
    125 typhoon
    a driver, preferably one you can fit a ratchet onto, halfords sell them and cost about 4 quid each for a socket version. from memory, a 5mm drilling will take a T30 torx.
