removing front wheel?
Discussion in 'The Workshop' started by oliwest, Apr 6, 2012.
  1. oliwest
    oliwest Member
    aerox road legal pit
    How the fck do i get the front wheel off my NRG power? I have un done the nut an the little allen key nuts on the fork leg. I have tried hitting the spindle with a rubber mallet an it still wont budge? Want to spray my wheel! :(
  2. h.hubbyy
    h.hubbyy Member
    JOG R
    checked if the break is blocking it?
  3. oliwest
    oliwest Member
    I just need to take out the bar from the forks thats holding the wheel on. My aerox was simple as, remove bolt tap it with hammer an slid it off but this is a piss take ahaha
  4. oliwest
    oliwest Member
    Got pissed off smacked it with a hammer HARD an it shot out accros the garage :L just sanded and primered the wheel. Need some paint remover as i now have a white tyre lol
  5. Stathis
    Nrg Power 70cc
    haha nice job :p :p was it easy to undo the bolts??? what did you use??? i want to remove mine aswell.. :)
  6. oliwest
    oliwest Member
    Theres 2 small allen key bolts on the left leg (looking at it from the front) undo them, then the main nut on the fork leg with the caliper an then smack the end of the spindle with. Rubber hammer HARD! An itll come out :)
    Just don tpull the brake lever or youll have to jam the pads apart
  7. Stig
    Stig Well-Known Member
    EXUP1000
    IF youre gunna smack the end with a hammer, leave the nut on but loosen it a few turns so theres a gap between the nut and ofrk. This will stop the threads deforming when you hit it....simply wind the nut off when the axles loose
  8. oliwest
    oliwest Member
    Ahh good tip, cheer mate :) ill do that when i next take it off
  9. Stig
    EXUP1000
