How do I remove the carb on 2013 aerox r the right way? fitted a foam filter and need to upjet and not really sure where to start, cant find any good videos online. if someone could link a good one or let me know how that would be great cheers also whats the stock main jet size
Airbox off. Seat bucket off. Remove the clamp between the carb and intake. Pull the carb off.. If you are just changing the jet, you don't need to take it totally off. Turn it upside down and remove float bowl. Swap the jet. Watch the float bowl pin doesn't fall out when you take the bowl off
