remove ignition barrel from gilera stalker
Discussion in 'The Workshop' started by bikerfish, Sep 10, 2010.
  1. bikerfish
    bikerfish New Member
    Hi
    my son had unfortunate accident today where the ingnition barrel seemed to get stuck and locked the steering to the right
    it seems to have a very tight spot on turning. i have managed to remove the electrical bit off the back how do you get the key part out, please
    j
  2. gart
    gart Member
    speedfight 2 100cc
    i think there is a screw some were on it? not sure tho cause i was fitting an alarm on my speedfight and i seen a screw for it to take it off *not 100% sure tho.
  3. bikerfish
    Re: remove ignition barrel from gilera stalker Help
    Still cant figure out how to remove the whole locking system from the frame. can anyone help
    please.
    i removed the switch from the back but just cant work out how to replace the whole thing as it seems to be badly worn
    many thanks
    j
  4. bikerfish
    Finally removed it now i need to get the forks out. i have loosened the bolt going through the handle bars what else do i need to do to remove the forks? i cant get the handle bars to come off any ideas
  5. barrybd
    barrybd New Member
    how did you do it I have the same problem
