Removal of Aerox Wheel Bearings
Discussion in 'Scooter Tuning' started by chris081277, Mar 6, 2008.
  1. chris081277
    chris081277 New Member
    Does anyone have any tricks on removing the bearings from the front Aerox wheel? I'm wanting to get my rims powder coated, and I need to get the bearings out and was wondering the best way to do that?
    Any pointers?
  2. Nrg-Sam
    Nrg-Sam Active Member
    put a screwdriver inside the bearing and wobble it round, it should reveal a metal tube inbetween them
    put the screwdriver on the edge of this tube, few sharp hits with a hammer and should pop out easy :cool:
    sam :cool:
  3. alexsr70
    alexsr70 New Member
    you need a hammer, drift and a wheel bearing driving....
    put the drift though first bearing to the lip of the second and knock it out, then flip wheel over and remove the spacer then knock out the other one
    grease new bearings (lm2 is good) then drive them back in
    dont drive the bearings fully against the spacer, leave a lil freeplay as it will tighten against it when you fit the new front wheel
    a drift is like a metal bar btw
  4. chris081277
    You guys rock.......as always.
    THANKS!!!!!!!
