hi ive got a runner 172 and im wonderin which would be the best reedblock to buy for it and where to get them cheapest. please give me some help!!!!
cheers for that what the v force 3 they look quite expensive but i dont no where you can buy them from?plus are they ne good.......
the vforce series of reedblocks was originally designed for the motorcross scene. and provides a better throttle response, so if its good enough for mx then it should be good enough for peds. but i think ive seen them on either scooterattack sip-scooters or scooter-center
The vforce would normally be good but for stage6 to sell them as cheap as they do they had to change the reeds to shit ones. They are good if you cut some polini reedsheets into the right shapes. I'm pretty sure James did it with his. You can only buy them off scooter attack.
just because it works for motocross it doesn't mean it's gonna work for scooters. MX bikes are constantly changing speeds therefore need sharper harsher throttle responses, scooters tend to be fairly steady in their speed changes therefore the throttle response isn't as important but the smoothness of the constant one speed running is more important. however the Vforce is a damn good reedblock.
