Picking some up tonight. Bikes been running like SHIT,uneven revs,bad bogging,18mph full throttle on a straigh,slow when warm,just generally shitty. Bearing in mind ive run out of fuel 2 times,i thought red ex might cure it a little incase ive blocked anything from draggin up shit from the bottom of the tank,ifnot then ill have to think of something else. But ill go and fill up with a fiver of fuel later,how much red ex do i need to put in the tank? Obviously it might say on the bottle,but whats your opinion? Thanks. Fucking peds. :bird: :up:
Erm, designed for clearing shit out of cars with high milage. who knows let us know how it goes yo's.... :w00t:
dont touch it.. redex is an octain booster.. bike dont need it and it will only run worse (if its better somthings not right) flushers/system cleaners are also useless with 2t as it turns the oil to piss and bang go your mains.. theres a lil filter in the tank stopping you takin anything serious down from your tank so just whip off the float bowl an check the float is moving/working as it should be. might be time to renew the transmission and set it up for the hot wether.. (heat nocks carbs out of tune)
