Recommended sparkplug is not working Stage 6 streetrace 70cc
Discussion in 'General Scooter Discussion' started by Tornado26, Apr 28, 2023.
  1. Tornado26
    Tornado26 New Member
    Hi, I recently fitted a 70cc stretrace kit to a Yamaha Aerox, I use the recommended BR9ES plug but it seems to hit the top of the piston and prevent it from firing. Have tested with an old B7HS plug which makes it start and roll forward but it is short threaded. Any suggestions? I have fitted all the included gaskets and measured the squish at 0.7-0.8mm
  2. Stevep
    Run with the shorter plug, won't do it any harm.
    But make sure the longer one hasn't holed the piston crown
  3. Tornado26
    Won't I loose performance? It will not be positioned right in the expansion chamber
  4. Stevep
    Not that you'll notice. Plus it's not so close as to cause a firing hole in the piston crown.
    A lot of people make the mistake of running the plug too close to the piston when calculating the squish. If you get too close, the spark on the plug electrode erodes the very top point of the piston causing a hole in it.
    Basically, it's spark erosion. And happens very quickly on aluminium.
