realy stupid question
Discussion in 'The Workshop' started by nottznutter09, Mar 17, 2010.
  1. nottznutter09
    nottznutter09 New Member
    anything once
    hiya fellas has you may have seen in other posts i have a neos 100 well i wanna do the renthal handlebar conversion. the only thing stopping me is the light,horn,indicator switches etc there built in with the handlebar fairing.
    i was wondering if the handlebar switches have to be on the handlebar for it too pass the mot next year or could i just cut out the holes for the switches in the top of the inner leg shield and fit them in there.
    my second idea was to get the handlebar switch gear for an aerox but i dont realy wanna fook around chopping all the wiring up or does anyone know if there the same connection ends
    thanks for youre time fellas
  2. DUNKMAN
    DUNKMAN Member
    yamaha neos 50
    hiya i dunno whether the connectors will fit , problably have to do some splicing and testing to figure out the right set up but as for the switches could you use something like this ????
    ( http://cgi.ebay.co.uk/Indicator-Lig...%2BUFI&otn=10&ps=63&clkid=7827175005767259656 ) ( sorry if ur not aloud to post ebay links im not sure if you can or not)
    i was thinking about doing it to my 50cc neos,,and is ur 100cc cured of its problems yet i know uv had quite a few :pale:
    good luck and let me know how and what u do to make it work ,as im thinking of doing it to :) .
    can u cut out a part of the floor pannle and put the speedo section in it to save cash on the digital speedos?? and lights??
  3. bait
    bait Active Member
    indicator has to be in thumbs reach other then that if switches are there somewhere like some one on here put them in the knee pan and yes those switches will work or stage 6 sell them or u could use aerox 1s not sure how close they are to the neos wiring wise but both made by yamaha so at a guess it wont be far dno about the speedo thing sounds abit dogy really as the speedo cable will have loads of slack and could get caught in the wheel or sumin your better off leaving as is if you dont wna spend the money or buying a set of koso clocks for round 80 quid and when it comes to selling the bike put standard bars clocks switches and fairing back on then selling bars stem switches and kosos or watever on seperate
