Really Slow After Fitting Lazer x pro
Discussion in 'Scooter Tuning' started by Tiagz17, Oct 27, 2009.
  1. Tiagz17
    Tiagz17 New Member
    Gilera Runner SP50
    today i got my lazer xpro and i got the restrictor taken out but ive lost a huge amount of power, take off is slow and only just reaches 40mph i also put in a white contra and 4g rollers
    im going to a mates to put my 3g back in to see if this is the case
    my set-up atm is
    polini cast iron 70
    17.5 carb with 58 jet
    9 roller polini vario
    polini super speed clutch
    kevlar belt
    white contra
    4g rollers
    help much appreciated
    cheers
  2. rideorcollide
    rideorcollide Active Member
    TYPH 172
    i think lazer x pros are just shit.
    i tried one on my zip sp before and it was soooo shit compared to the pther pipes i used.
    people said they need setting up diffrently but tbh i think that peepz only say to buy them because they give alright gains on a sport setup and theyre cheap, but if you actually wanna go fast then you want a diffrent pipe
  3. safekyle
    safekyle New Member
    Gilera runner 172
    and upjet and heavier rollers ?
    clutch springs
    stock contra.
  4. Tiagz17
    Tiagz17 New Member
    Gilera Runner SP50
    i see what ur sayin J
    ive found the problem, my 4g were too heavy so i fitted my 3's bk in + my carb is loose from the manifold and airfilter so was sucking in air...need jubilee clips
    but shud ave the 21mm in soon so shud b flying :)
  5. capri dave
    capri dave Active Member
    The Laser xpro is a very revvy pipe compared to most other sports pipes, it develops a lot of horse power at the top of the power band, but this comes at the price of low/mid range torque...
    that is why most people experiance their bikes actually going slower when they fit an xpro...
    to get the most out of the pipe, your whole transmission has to be set up to suit the different characteristics of the pipe...
    i used an xpro for quite a while, it was a good pipe once the tranny was set up properly, this takes time and patience....and yes my bike went slower when i 1st bolted it on in place of a zx ;)
  6. Tiagz17
    Tiagz17 New Member
    Gilera Runner SP50
    Cheers Dave, I am now assured that it wasnt just hapening to me lol
  7. capri dave
  8. Tiagz17
    Tiagz17 New Member
    Gilera Runner SP50
    very good info there, i now understand,i got my pipe derestriced as there was like a restrictr and the begining of the pipe where it mounths to the engine, so far its running okay, but im on a 58 jet so im nt riding it much as its wrong and i do not have 6mm jets, although i do have my manual choke and 5mm jets for my 21mm carb so ima fit that on probably on the monday coming and see if power is anymore increased. also thinking of a open air filter, this a good idea?
    thanks
  9. greg531
    greg531 Member
    I am running a 72 jet in my Typhoon.....with the original air box and Malossi Red Sponge...
    You are running way too lean with a 58 jet with a 70 kit! If you get a free flow airfilter....you will have to go up to around a 88 to 100 jet, a lot more gas, and not much more proformance....
    Your rollers are too light, I tried 4.25's, and mine ran crappy, and went back to 4.5's....Are you using your medium clutch springs? Hope this helps....
  10. Tiagz17
    Tiagz17 New Member
    Gilera Runner SP50
    i see what your saying, im trying to ride my bike as little as possible, bcoz ive got my 21mm carb here with choke and jets ready to go on, just want my m8 to do it for me (lazy)...and seeing what you said, i could just get a red sponge too, as for the springs, i got 2 sets, one came fitted and ones that came ina bag had blue on them?....and the rollers are that light because i have the polini 9 roller vario and from what ive tested the bike runs best with these rollers.
