Aerox has an electrical fault and I cant sort it out.cant get the tail light or head light working , break light works ok.when I put a multi meter on the battery its reading 12.2 volts but wheni start it up the voltage drops instead of going higher, ive checked stator, cdi, coil can t think of any thing else.is there such a thing as a haynes manual for a 2009 aerox .theres one on ebay but theres no picture to see if it is, Can get the 1997 to 2006 manual but the 2009 is different.cheers in advance if you can help.
With the engine running at about 2000rpm the meter should read about 14.2volts. Anything below this and the stator is shot or the battery has a dead or dying cell in it. The other cause is the regulator/rectifier, but this normally coincides with BULBS BLOWING FOR NO REASON. Brake light is a different circuit as the engine doesn't need to be running for it to work, but the headlight and sidelight do.
