radiator fluid
Discussion in 'General Scooter Discussion' started by JaMeZ, Jun 1, 2008.
  1. JaMeZ
    JaMeZ New Member
    just wonderin wat u guys put in your radiators? thought it was water but thought i heard mention of other fluids being used. just to clarify
    cheers
  2. kyle1b1
    can buy ready mixed coolant.
    or just mix your own.
    50/50 with water and antifreeze
  3. JaMeZ
    JaMeZ New Member
    is it alot better than just water?
  4. capri dave
    capri dave Active Member
    yep a lot better ;)
  5. JaMeZ
    JaMeZ New Member
    ok thanks very much :D
  6. Tom
    Tom Member
    distilled water, right? rather than just water.
  7. kyle1b1
    can use it.
    but normal water is fine.
  8. aprilia172
    aprilia172 New Member
    buy ready mixed its easyer, anti freeze works in 3 ways it has stuff to stop corosion in ya water system, runs cooler than plain water and suprise suprise stops ya water freezing.
    if your thinking of just using water dont bother as the water in your engine freezes in winter it expands causing cracked barrels, rads and pipework
  9. Crana
    Crana Active Member
    My mate lost his barrel to the winter because never had anti-freeze in his bike...
    Its great stuff it stops rust aswell
  10. JaMeZ
    JaMeZ New Member
    wow im so glad i asked this before any cold weather struck i never really knew to use anti-freeze and i wud av been so pissed if i fucked my barrel because of it.
    thanks
  11. StEvO
    StEvO Active Member
    dont think u can just stick as much antifreeze in as you want,
    too much corrodes things like waterpumps, thats why u go by manufactures ratio's
  12. Tom
    Tom Member
    50/50 is what i did. although i dont think i even needed that much, just what mr haynes reccomended :nerd:
  13. capri dave
    50/50 is a safe mixture for most vehicles ;)
  14. aprilia172
    or just buy ready mixed. is same price as dilute and you dont get left with half a bottle of dilute you will never use.
    eco aprilia lol
  15. lol
    lol New Member
    i yous neat coolant and it sem to kepp my bike well cool and i heard that water rusts water pump and things
  16. aprilia172
    with neat coolent your bike will run cooler but it will also not reach its optimal running temp this leads to premature wear and less performance(gulp).
    it will keep rust down but react in a different way causing early failure of parts its in contact with.
    unless you mean neat as in pre mixed then its fine
  17. lol
    lol New Member
    might drain a bit of coolant out then and put some water in theyso u lot recon 50/50
  18. aprilia172
    yeay mate should be fine
