Quick action(tiny bit 2 small??)
Discussion in 'The Workshop' started by Batesy17, Mar 11, 2011.
  1. Batesy17
    Batesy17 Member
    Ok so fitted the stage6 quick action (cables straight to carb for premix), but it revs way to high and wants to take off while on the stand. Ive adjusted the idle but the problem is if i take the cable off the thing that the quick action goes around so that it has a TINY INCY WINCY bit more slack, it runs fine :/ (the white circle thing showed in the picture)
    Uploaded with ImageShack.us
    Im pretty sure ive adjusted all the cable so i cant make it anymore slacker
    Anyone have any ideas? dont want to get a new cable made up when its a tinyiest bit of slack i need :mad:
    I have a runner 172, with 28mm slide carb if that helps
    Thanks
  2. yellasei
    yellasei Member
    125 typhoon
    Re: Runner 172, Smoking after Qwik action fitted.
    are you running pre-mix now?? it does sound like the slide might not be in properly.
  3. Batesy17
    Batesy17 Member
    Yeah ive just fitted the quick action today to start running pre-mix, so the cable goes straight to the carb. I put a little oil in the tank as i dont know how much petrol is left in there and i only wanted to start the bike to check if the throttle would work but then found out it wouldnt run properly.
    I will have a look at the slide tommorow thanks :) , wish i had a bigger shed so i could work on it now :(
  4. yellasei
    yellasei Member
    125 typhoon
    cool, the smoke might just be too much oil mix. you should re-jet when moving from a pump to pre-mix as the oil going in with the fuel changes the mixture.
  5. Batesy17
    Batesy17 Member
    Bump - Edited.
  6. northrider
    northrider Member
    it could be because ure using a 28mm carb ive heard people have hard troubles before or maybe the cable supplied is for a 50 and u need to get a longer 1
  7. Batesy17
    Batesy17 Member
    If it that its too small. its a shame as i only need an extra inch lol :banghead:
  8. tErr0
    Gotta be that the cable isn't long enough. You have an adjuster on both the throttle and the carb as well so if it's only a tiny bit and you haven't done that yet you might be able to.
