pulling back when pulling away ?
Discussion in 'The Workshop' started by Hursty, Jan 2, 2008.
  1. Hursty
    Hursty New Member
    when i pull away it dies.. let go of the throttle and its ok again
    have to hold the throttle on very slightly to pull away?
    any ideas?
    jetting ?
    cheers
    ben.
  2. piaggiozipkid50
    piaggiozipkid50 New Member
    i had the same problem then i sorted my jets out an it has been fine ever since.
  3. Hursty
    Hursty New Member
    if it needs a smaller jet.. im screwed lol
    only got 75 and above.. and its got the 75 in there
    ben.
  4. Jamie
    its mostlikely because your full throttleing from standstill. and your main jet is too large, so too much petrol is going in at a low rpm and bogging in out.
    put a smaller jet in and see how it goes
  5. tweak
    tweak Member
    Drop the needle and make sure the dodgy choke cable you have isn't still partially on after you've started it.
  6. Hursty
    Hursty New Member
    drop the needle how far ?
    ben.
  7. tweak
    tweak Member
    Plug chop first, then go from there.
  8. Hursty
    Hursty New Member
    dark black and wet
    ben.
  9. SMF_12
    SMF_12 New Member
    you need a 42 jet int here then mate
    I will not be held responsible if you do put one in there tho!
  10. MiNoR cOnFuSiOn
    reight,m wind the idle mix out a half turn at a time an try it.. bang the needle down one notch and try it,.. try lighter rollers...
    most of all id puyt this down to clutch springs.. does it rev fine full throttle once your doing 10mph plus?
  11. CRAZY EYES
    CRAZY EYES New Member
    Silly thing to say, but i had the same problem when i was a newbie to tuning, I had put a clear float bowl on my 25mm from PM, and i came with a new type fixing bolt.
    Once fitted it did the same as you, it'd run fine intill i opened it up then it'd die, until i rolled off the throttle then it'd be fine.
    I'm sure you can see where this is going, yes you guessed it, i put the float bowl back on with no main jet in the bolt, :wtf: :emb: (i never knew that was where the jet had to go lol)
    Anyway, moral of the story, is there a jet in there at all?? I'm sure you're not as silly as me but hey!
  12. Hursty
    Hursty New Member
    yup.. but i only got 4.3g rollers in there:confused:
    ill try dropping the needle first
    but i got a 75 jet in it.. with a malossi sport 70 kit.. 19mm carb.. standard air box
    cheers
    ben.
  13. Hursty
    Hursty New Member
    lol yeh theres a jet in there :p
    ben.
  14. MiNoR cOnFuSiOn
    clutch springs and the jets too big for the stock box
  15. Hursty
    Hursty New Member
    got polini yellow springs in lool.. hmmz.. +70 or 80% or sumthin
    how far roughly would i have to go down on the jets?
    cheers minor
    ben.
  16. MiNoR cOnFuSiOn
  17. Hursty
    Hursty New Member
    whats the idle mix screw ? (the air mixture screw) ?
    and how much do i need to adjust it minor ?
    cheers mate
    ben.
  18. Dann
    Dann New Member
    probably a chav behind ya trying to steal ya wheel nuts.
  19. Hursty
    Hursty New Member
    im confused :wtf:
