Hi there, Got a problem with my scoot, This morning on my way to college it was fine. When I left for college it was ok, then I pulled up to some traffic lights and my throttle twist went funny for a second felt like it went slack. But then taught again, now from here my scooter would be really slow pulling away and continue slow until 20mph after 20 it would be alright it sounded really flat and slow. I've got a few problems in mind Clutch gone? Drive belt stretched badly Rollers? The rollers have recently been done so I could maybe rule that out. Clutch and belt may be likelly? Anything else? I'm reluctant to ride it because It's dangerously slow out of junctions!
be loads of play in belt if so or obvious bad condition? or clutch dust all over which there was a while ago!
check thr beltt for damage like cracks and splits and see how much it streches and clutcg dust not so bad but just take it off and look
i lock mine up with a u bolt through the bell holes and a pip through the u bolt touching the ground so it lock and undo the bolt
ah right sound mate will give it a blast can't be dealing with having it off the road! dangerously slow pulling away
theres a bit of white thread coming off belt and noticed oil ontop of cvt case so gonna get some brake cleaner clean it up and get a belt! will replace asap with the white thread I can see! looks old and starting to go shiny so that indicates belt to me! thanks Lee!
Well going to order the new belt tomorrow, just a standard one not splashing out on expensive bits when I plan on getting rid of next month! I'm thinking Theres oil managed to get onto the belt etc from where it's leaved out my seat bucket as theres oil all over the frame etc! my bad! so just going to get some brake cleaner from halfords and give it a good spray and clean and chuck the new belt on, Should I expect similar symptoms until the belt is ran in? cheers
Hey Lee, No it didn't took clutch off it looks worn out like, thinking of just flogging it now, on the verge of quitting my shitty job and finding a full time job so may sell it to fund my un employment haha
I'd check the rollers if they were the most recent thing to have been changed. You may have a faulty one?
