Pull off
Discussion in 'The Workshop' started by clarkey90, Oct 8, 2010.
  1. clarkey90
    clarkey90 New Member
    Zip SP (58)
    When i go to pull off, i have to basically give it full wack until the revs build up then it shoots off.
    On my mates all you have to do is well, pull it a bit and it goes.
    Not to good with the mechanical side of scooters
    and its probably and easy fix.
    Thank you.
  2. gart
    gart Member
    speedfight 2 100cc
    i think you need to adujst the idel screw or the throttel
  3. Benrg
    Benrg New Member
    Mine also does this. Which screw is the idle screw on the carb? Picture highlighting would be helpful :)
  4. gart
    gart Member
    speedfight 2 100cc
  5. bertie
    bertie Active Member
    '93 Skipper LX125
    The first thing you should check are the rollers. Probably just worn out or too heavy.
    The throttle and idle screw should be fine as it is, if it ticks over nicely (1,500rpm) then the idle mix is good.
  6. clarkey90
    Zip SP (58)
    Had new rollers fit in about 2 weeks ago, there 4.5g
    Night have a little play with my air and idle screw just to see if i can get it right.
    Thanks anyway
