http://www.gumtree.com/p/cars-vans-...iliaziptyphoon-swaps/1057517926#photo-content For sale is my beloved 2 stroke Piaggio NRG Power DD 2005 70. I've had it since august and i've had it off the road since October to the beginning of Febuary. During that period i've had the engine rebuilt by DWR motorcycles, and done lots of bits to it because it wasnt looked after by the previous owner. I've spent hundreds but i want a geared bike and i've done everything i want to do to this. It's very fast (hits 60) and handles well, has been run in properly and i run it on BP premium 97 fuel and quality castrol oil. Done 500 miles since it's been rebuilt! Sadly recently it's stopped running due to low compression (compression test shown in pictures). It was running absolutely fine, but i washed it, went down the road and it just stopped running. I've cleaned out the carb and jets, checked the reeds, bought a new inlet manifold 2 days ago but havent had any luck. Here's whats been done; Performance: Stage 6 Streetrace 70cc Malossi RHQ Crankshaft Malossi Red Sponge Insert + Removed Airbox Snorkel Stage 6 Pro Replica Exhaust Heavy Duty Crankshaft Bearings And Seals Motoforce Evolution Sports/Race Clutch Racing Reed Valve Block Malossi X Special Belt De-Restricted Inlet Manifold Stage6 Medium Torque Spring Stage6 107mm Clutch bell Stock 17.5mm carb with 90 Main jet Needed: Exhaust Studs, Bolts and Gasket New Spark Plug New Engine Case New Inlet/Reed Gaskets New Water Pump Kit New Oil Pump Belt New Rear Wheel Bolts New Kickstart Case and kickstart New Battery Standard Rear Light New Rear Tyre (less than 30 miles on it) Visuals: Stage6 Adjustable Jack Up Riser Kit - Carbon Side Stand + Remove Centre Stand Matte Black Respray Custom Rear Indicators (were already on bike) 6x4 Numberplate Carbon Look Brake Levers Xenon H8 Headlight Bulbs Fly Eye Tinted Headlights NRG MC3 Wheels Powdercoated White Has tax until October and MOT until September. Few bad bits: Snapped rear brake lever, needs a front brake light switch, horn doesnt always work and the temp gauge has stopped working. £450ono, Aylesbury. Text/whatsapp/call 07450849026 Will swap for another 50cc or project
