problems already -_-
Discussion in 'Maxiscooter Tuning' started by Speedy 172, Oct 4, 2007.
  1. Speedy 172
    Speedy 172 Active Member
    right heres my set up
    malossi 70 kit
    endy race pipe
    100cc manifold
    17.5mm dellorto carb
    7.5 gram rollers
    86 jet - 72 standard
    well first off my bike doesnt idle it cuts out
    its really smokey when at a stand still
    takes a while to pull off
    after full throttling it if you take off the revs then rev again it just bogs till it slows to 30mph then goes bk up again
    and tops out at 47 mph :rtfm: :rtfm: :rtfm: :rtfm:
    and secondly since ive been back on the road when my bike gets over 45 mph theres a rumbling sound coming from my transmition :rtfm: :rtfm:
    any clues ???
  2. Hursty
    Hursty New Member
    is it a standard crank ? if so how many miles has the bike done ?
    could be main bearings
    and sounds like your jetting is too rich.. check your plug
    (and please mate.. get my mudguard to me :rtfm: )
    ben.
  3. Speedy 172
    blud as far as i no its sent :rtfm: :rtfm: :rtfm:
    fuckin mothers
    il call in mornin :punk:
  4. Speedy 172
    bikes an 02 done maybe 20,000 kmhs
  5. Hursty
    Hursty New Member
    hmm.. does it rev high (i.e light rollers) ?
    EDIT: try playing around with the mixture screw.. could be too much or not enough air coming through
    ben.
  6. Speedy 172
    not really :wtf:
    i was told 7.5 was a lil to light for my set up tho if that counts for anything
  7. Hursty
    Hursty New Member
    imo.. too much air or too little air.. just play with the mixture screw
  8. Sw1fT
    Sw1fT Active Member
    200SX S13
    7.5 are too heavy
    the pipe is too shit
    the jetting will probably need a few tweaks.
  9. Speedy 172
    tryed the mixture screw :rtfm:
    my uncles a bike mechanic hes played round with it and it still takes like an hour to reach high revs :rtfm: :rtfm: :rtfm:
  10. kyle1b1
    rollers too heavy is it takes aes to get high revs
    sw1ft already said
  11. Speedy 172
    oooooops :pimp: :pimp:
    didnt see swifts post :rofl: ;)
  12. Speedy 172
    anyone no why top end would be so naff then ?
  13. Sw1fT
    Sw1fT Active Member
    200SX S13
    that would be the pipes fault haha
    rollers could be killing top end, this is the vivacity yeh?
  14. Speedy 172
    yea :D
    the pipes a real improvement compared to standard tho :punk: :punk:
  15. capri dave
    capri dave Active Member
    theres no post...post men are on strike!!
  16. MiNoR cOnFuSiOn
    iuf the rollers are too heavy you wont have the centrifugal force to fling them to the outer edge of the ramps = cant hit the upper gearing ratios= shit top end
  17. Speedy 172
    sorted the vibrations and whirling sounds :punk: :punk:
    1. i forgot to bolt my exhaust on properly :pimp: :pimp:
    2. my rollers are worn :p :p
    so can anyone suggest a suitable size for my set up ?
    :punk: :punk:
  18. J-Nitro
    J-Nitro Active Member
    try different jets and play with the mixture screw i no its probably old advise but thats exactly what my nitro is doing, going to change the mixture tommorow, was working fine before its just i wanted to get the right spark plug colour
    sounds like the mix is wrong
  19. Speedy 172
    will do :p
    anyone no if the carb needle could need moving :D
