pressing a crank
Discussion in 'The Workshop' started by A-LY, Nov 10, 2012.
  1. A-LY
    A-LY Active Member
    well im on about putting a 70s in my aerox soon and im gonna do the crank for reliability. im kinda torn between how to do it.
    i can either pay a mechanic £50 to press it, or do it myself with a blowtorch and a freezer.
    how easy is it to do myself? ive seen videos but i dont want to fuck it up
  2. astro77
    astro77 Active Member
    you want to do the bearings as well, put bearings and crank in a plastic bag spray them with wd40 first then freezer overnight, split cases heat around bearings with hot air gun then tap them out. get new bearings out the freezer, while case is still hot then tap new ones in, then heat the new bearings and get new crank out the freezer and fit in the hot bearings
  3. iNEEDaNEWped
    iNEEDaNEWped Member
    Pm tuning have a great video for it on youtube, when i get on a computer i'll link you, it's 3 parts and pretty detailed
  4. astro77
    should be pretty interesting to see how they do it, I presume it's aimed at the home mechanics
  5. iNEEDaNEWped
    iNEEDaNEWped Member
  6. iNEEDaNEWped
    iNEEDaNEWped Member
    On another note i think stage 6 cranks are already pre-pressed.
  7. A-LY
    A-LY Active Member
    what, as in already have the mains on them?
  8. astro77
    think your getting confused with gear up, chap:)
  9. iNEEDaNEWped
    iNEEDaNEWped Member
    Oh dear, it's been one of them days. Lol
  10. astro77
    ah we all have them from time to time :)
    iNEEDaNEWped likes this.
  11. scubabiker
    just to let you know, i snapped part of a crankcase last week pressing a crank out.
  12. A-LY
    A-LY Active Member
    how would i go about avoiding doing that?
  13. scubabiker
    just dont turn your puller too hard and keep heating the casings, when you put them in, use a few blocks of wood to keep the case parallell to the bench, use a good bearing punch/ socket if you dont have a bearing punch. and put the oil seals in first, they cant go in too far or you will block the oil channel coming down from the cylinder. and finally, dont punch on the inside of the bearing or you will fuck it. when putting the cases tyogether, use a tiiny bit of sealant ONE side, after you tighten the case bolts the crank might be a little tight, you can hit it with a copper hammer either side to loosen it (lack of thrusts does that). dont hit it too hard or you could bend it.
  14. 4strokelover
    4strokelover Active Member
    Longjia Raptor 200
    why is it that you have to freeze the parts and heat the bearings and cases?
    cause my mate just took his old crank out and put his new one in.
    just need to know for when i do mine
  15. astro77
    shrinks/expands the metal
    scubabiker likes this.
