Preg(96)Typhoon 125
Discussion in 'General Tuning' started by Csqjohn, Mar 30, 2014.
  1. Csqjohn
    Csqjohn Member
    hi got old typh going to buy a new crank anyone know the best place to get one also is it best to stick with the 52mm crank?
  2. turbovetto
    turbovetto Well-Known Member
    tweaked ovetto
    Definitely stick to the same crank dimensions you have. If you change the length of the con rod you'll have to shim up the cylinder up by the difference in length. If you change the stroke, you will have to either adjust the porting or replace the cylinder for one that goes with the crank.
    I assume we are talking about a 2 stroke 125.....
  3. ziggy_tph125
    ziggy_tph125 SONIC BOOOOM!!
    Piaggio Typoon 125,
    C.B.S whitton is were i get all my bits in from but all depends were u live? internet is your best bet but do your homwork on the company befor you buy ;)
  4. turbovetto
    tweaked ovetto
    Think Top Perf/Doppler/Malossi in ascending order of quality/price.
