someone needs to kick the bike on the left over crappy chineese 4-strokes but the aerox and zip are looking piff!
i spent £500 recently... add the £150 yasuni R onto that.. and it doesnt even start ...LOL why cant you wire up your lights ?
They just dont make sense lol ment to basically just "screw on" do they fuck i have 2 wires for each indicator as standard these come with 3 no instructions and no one has replied to my post lol. Also i know that I need two resistors so thats another £12 excluding p&p as they make all the indicators flash way too quickly, and I cant figure out how the side light is ment to be wired as it cant go through the indicators can it? otherwise they will only work when indicating and will be flashing lol. And all i know is green is common earth and I have 2 +12v wires Another really annoying problem is I put a 62 jet in up from a 60 and the bike just looses all of its revs and power at full throttle when its still running lean with a bigger jet makes no sense.
on the aerox isnt it black thats earth? im sure mine was. i managed to wire up the twin halogen light on my aerox without to much trouble and i wired up a rear lexus light with led indis, for the rear you had to join all the bikes rear earth wires into one and then plug it into the new light
Well ive found out with some experiments and a multimeter anyways you have to wire the green into the negative of the indicator and wire the blue wire to positive for the indicator... then with the white wire you need to wire it to somewhere positive but not the indicator positive or it will only run if indicator is on and will flash lol and not to battery either or it will run for ever or use a switch for them.
on the aerox you should have 3 wires for lights, one is side lights, which you use for dipped, one for dipped which you gnore and one for high beam which you wire to high beam, unless your new light has a dipped main and side lide, in which case use all 3 wires, if your bike only has dipped and main and u need side lights, make a y joint off the dipped light and run it too the sides?
Im only for the pictures but i thought i would upload my too Please dont hate its a little runner to get me from A to B ( The fairings are knackered but all it matters that its a great little machine! ) Top speed 51mph ... as i run into traffic -.- it will hit round 65ish i reckon
here's some of the bikes ive had speedfight 120, speedfight 70, aerox 70, runner 180.. two geared but thought id stick em in dt125 and the new baby ktm 690 still got spedfight 120 and ktm 690
you do know your bike clocks lie don't you. if you bike says 50 you can bet your going 42-45. my old NRG told me i was doing 70 but when i put air in the front wheel it dropped the top speed. the clocks are only true to about 35 because thats all there intended to do
