ok so on my tph i get not too bad pull of but its not on its full power , also i only get 45 ish out of it and it slightly bog down if i rev full throttle straight away there is my set up : malossi sport 70 leovence zx derestricted 17.5 carb 70 jet, airbox malossi variator 4.6 and 7.2 rolers stage 6 belt any ideas? because my friends aerox runs same set up just with yasuni r and hes rox pulls like hell
checked the reeds? also give your carb a clean, although you will probably be better off with a 20.5 or 21ml to release the full potential, as if your mate is running a 17.5 on an aerox that is not the standard carb for the bike
Change your jet, im running a 50s with a 70 jet and its perfect. Also a 70s should not be doing 45 lol. Like revolution said get a 21 ml carb
ok i have done some adjustments to the bike and its doing like 50-55 now but still bogs abit , could this be the pipe ? as i heard that they r kinda crap? as my 70cc aprilia wasnt running well with tis pipe on ?
ok so today i fittted the 20.5 carb from 125 bike, got everything together keep on going down on jets and ended up on 53 jet ?? it works the best on it but still bogs at 40 , my needle tjing is on the highest clip now ill try changing that , but could there be any other problems like rollers or something ??
