polish 70 kits
Discussion in 'The Workshop' started by A-LY, Nov 17, 2012.
  1. A-LY
    A-LY Active Member
  2. astro77
    astro77 Active Member
    wow 25 quid if you take the postage off, but you must have to use oem cylinder head as I can't see one in the add, gonna have rough ports as the cheap Chinese ones always do, but do a bit of work on it and could be ok for the price.
  3. A-LY
    A-LY Active Member
    yea its says i have to use my standard onit and 70 heads wont fit. im expecting it to have rough as fuck ports, but dads just bought a dremel and has an endless supply of cutting tools for it.
    dont know if it actually is chinese, its from poland so maybe its some little shady place bangin em out cheap
  4. A-LY
    A-LY Active Member
    i would be fine running this on a standard aerox crank right?
  5. astro77
    yeah mate for that price it will be cast iron with mild port timing's, as for reliability, who knows
  6. A-LY
    A-LY Active Member
    I think ill end up cutting the exhaust port like 1mm higher
  7. scubabiker
    you know that transfers need some roughness to them right? if they are shiney amooth, the mixture seperates, the rough surface agitates the mixture as it flows over the top of the surface. but the casting will probably be shite so you might want to open them up a little and take the big blobs of cast off. i was thinking of using one of them for my daelim, let me know if they are any good
  8. A-LY
    A-LY Active Member
    what do you mean by 'open them up'?
  9. astro77
    yeah I know mate
  10. scubabiker
    i mean make sure the transfers are matching the crankcase, make sure that the transfer ports in the cylinder are matching each other in height and width etc.
  11. DC53
    DC53 Member
    Vespa 210, bws 125
    As with everything, you get what you pay for. will still increase power though so worth it for that price! make sure you chamfer the ports, as i have tried cheap 70 kits in the past and they eat through rings!
  12. A-LY
    A-LY Active Member
    how much should i chamfer them?
    and what kinda tool?
    i dont want to go fucking up the bore by trying to chamfer them
  13. DC53
    DC53 Member
    Vespa 210, bws 125
    Not alot, just so it smooths off the edges slightly to stop rings getting into contact with the ports. As it's cheap the castings will probably be a bit rough so just double check :)
    You will need a dremel and some decent attachments
    I'd suggest getting someone who has done porting in the past to do it as it's rather tricky, but you gotta practice somewhere :)
  14. murerg
    murerg MBK Hero!!!
  15. A-LY
    A-LY Active Member
    if i was going to pay that much id just get a stage6 streetrace. the only reason im looking at this thing is because its cheap and i wont be as worried about porting it and breaking it
  16. murerg
    murerg MBK Hero!!!
    Why dont you get a 50cc standard cylinder on ebay amd work on it? nothing better to see how you are getting on as you have the standard engine and the ported one~?
    If it was for practive, that s what I would do.
    It still doesnt change the fact that those mentionned above are uber rubbish! ;)
  17. A-LY
    A-LY Active Member
    i want more power aswell, what ill probably do is put it straight on, then do porting work snd compare the differance.
    what makes them so crap?
  18. A-LY
    A-LY Active Member
  19. FiddyRox
    FiddyRox Well-Known Member
    Aerox, CRF450, YZ125
    I'd go for it tbh, its good practise and for the money it should be a pretty good value performance increase
  20. A-LY
    A-LY Active Member
    the polish one or the one i just posted?
