Polini Speed Control Question - Quicky!
Discussion in 'Scooter Tuning' started by 2strokeracer, Apr 17, 2008.
  1. 2strokeracer
    2strokeracer New Member
  2. RY4N172
    RY4N172 New Member
    19x15.5 there 8g rollers mate
    Thats what i get anyway
  3. eddiesmith
    eddiesmith Member
    hi, for an aerox 50 u get 16x13 rollers, a set of 4.9s and 3.6s
  4. capri dave
    capri dave Active Member
    The quick answer is, they come with the same sized rollers as the scooter engine it is intended for ;)
  5. eddiesmith
    eddiesmith Member
    they dont becus the polini variator uses 16x13rollers on the aerox, wen the standard ones are 15x12 :D
  6. capri dave
    AAHH!!
    yeah just had a look on scooter attack, it seems the minarelli is fitted with
    tiny sized rollers as standard :p
    A good move would be to buy a variator that incorporates the Piaggio 19x15.5mm sized rollers....like the Doppler S2BR variator for instance ;)
    youll find the bigger rollers are far more durable, operate smoother and last longer too :D
  7. MiNoR cOnFuSiOn
    older piggy engines are but they realised the variator was eating them double quick. so larger surface area with a thinner spacer. can do this with any variator to reduce wear on rollers.
