Are they any good...coz I just got 1 for the zip SP :emb: (70cc polini iron barrel fitted, malossi reeds and block, racing inlet, Malossi variator and doppler clutch, malossi 21mm carb) thanks for any advise
Yes they're good. But you will need a higher revving kit to get the best performance out of it or you might as well of got a lazer x pro or a doppler s3r. Really you be wanting a Polini EVO II barrel and a after market crank to be getting the best use from that pipe. Well, So I'm lead to believe any way.
pheww those evo 9 pipes are about £300 aint they :wtf: they are meant to be High end....
sure are....£327 from pedstop, which is £7 more than I paid for both SP's together Ebay is your friend tho....£70
stig do you wanna sell it or swap for a new yasuni c16 city?. the c16 would work well if a bit of porting was done to the barrel too
no sorry, It looks a smart piece of kit. As long as it works OK with the current set up, then its keeper for now. Need to get this thing back in running order with the MOT sorted ASAP
OMG, that 2 members that I've probably pissed off since joining :emb: Just found out reading one of the other posts that I've outbid Nibbles for the ZIP 50 SP that he had his eye on Sorry mate http://www.scootershack.co.uk/viewtopic ... 638#151638
if i were you stig, do you self a favour and replace the polini sport with an evo, and a bigger carb (assuming you have new crank and mains since rebuild, if not then yea full circle crank would be an idea) will be a match made in heaven will work with a polini sport fine, just the pipe wont be performing no way near what it should be and thats no fun
thought about it but not worth the investment. Lad will be 17 in may and then wants to ride the RG125F that we're restoring at present....plus he'a hankering after taking his car test...and bike test later. the ped will probably get sold if he passes or gets the 125 completed
