polini evo kit,
Discussion in 'Scooter Tuning' started by scott712, Aug 27, 2008.
  1. scott712
    scott712 New Member
    S6 streetrace jog rr
    where is the best place to get one from, and wat mods would i need to do to my engine to stop it fryin,
  2. pimped_aerox2
    pimped_aerox2 New Member
    [/sizefirst of all you will need a crank that can withstand very high revs, a high end pipe something like a c21, a big carb 21mm and above, variator,clutch,belt,torque drive,reed block with carbon reeds,manifodl, could do with a electric water pump tbh seals are good in the manual ones. thats bout it rele to start you off then you can go into bits like gearing etc.
    i would warn you though its alot of hassel setting this up to get it to run well it takes alot of hard work and time. you cant just bolt it all on and expect to work. i know this from my own experience of just trying my own polini evolution 2 setup on my aerox and no i just cba tbh and am down grading cause you can tell its very high revs for the road.
    cheapest place is scooter centre at 190, just to let you know i am selling an evo2 bore 12mm, yasuni c21 pipe and a 21mm stage6 pwk flatside racing carb for 350-400 its brillent condition only done around 15miles then took it straight off.
  3. DYS VTR
    DYS VTR New Member
    skanky cRaKwhoR3s
    why the fuck would he NEED an electric water pump ? :confused:arc:
    a decent crank and some jets is ALL u need to stop it frying but it rould run like a piece of shit, ud need the majority of the parts listed above to get the most from it
