polini corsa honed?
Discussion in 'The Workshop' started by cormackaerox93, Apr 7, 2010.
  1. cormackaerox93
    cormackaerox93 New Member
    aerox70
    ive cooked my polini corsa 70 and am thinkin about gettin it honed, is this a good idea? and if i do get it honed will i need an oversize piston?.
    thanks
  2. bertie
    bertie Active Member
    '93 Skipper LX125
    Waste of time, money and effort. Even if its done well its still not gonna run as well or last very long. Much better off buying a better cylinder, polini corsa's are known to be fairly weak, powerful but dont last too long because its basiclly a polini sport 70 with harsher porting, kinda "souped up" version of the sport kit, being cast iron it runs hotter than an ali kit.
    So Id reccomend something like the Malossi MHR Rep because this is basiclly a race kit, de-tuned so it lasts longer than you might expect! Also its made of ali so it'll run cooler.
  3. Stig
    Stig Well-Known Member
    EXUP1000
    IF you DO go for the honing...no you wont need another piston unless theres damage to it or the rings. All a hone does is to remove the glaze and any high spots from the bore. The increase in diameter of the bore is so minimal that the std rings will take up the slack. This is obviously depending on how many times its been done before
  4. waxhead
    waxhead Member
    Buy a motoforce , great little cylinder good power last for ages and cheap
    More power than an mhr rep
  5. bertie
    '93 Skipper LX125
    For real? I always thought these were rubbish quality cylinders?
  6. waxhead
    waxhead Member
    Yes for real
    They are a great cylinder and make decent power as well
    I have fitted heaps of these now and the only issue i have had is when the needle roller exploded on one and went through destroying the piston
    I put a new piston in it and kept on running it
    I also raced a year on this cylinder before retiring it
