Polini - Clutch Springs + Contrast Spring
Discussion in 'Scooter Tuning' started by Aerox Aaron, Feb 7, 2008.
  1. Aerox Aaron
    Aerox Aaron New Member
    Just checking here, but i got the Green, Yellow and Normal clutch springs
    which ones are the stiffest am i right to thinking Yellow?
    and i got a White and Blue Contra Spring, Is the blue the one that wants putting in?
    Thanks All.
    oh yer, what would happen if you put too Heavy clutch springs in?
  2. alexsr70
    alexsr70 New Member
    kinda hard to tell you what parts to fit mate
    its trial and error and common sense so get trying
    but then again list what the bikes got and we might be able to advise a few setups
    oh and in answer to -
    = the bike would rev too much for pull off and then once it has pulled off there might not be enough power to keep the high revs, so the revs may drop
  3. White aerox
    White aerox New Member
    i have a malossi white contra spring and green polini clutch springs the yellow where to stiff for me
  4. Hursty
    Hursty New Member
    white contra spring.. green springs.. should do perfect (polini)
    green around +40%
    yellow around +60-70%
    white spring is perfect for me
    ben.
  5. Aerox Aaron
    Thanks all (Y)
    Helped alot.
