as the title says, my pm wobbles alot when i ride.. ive tightened it up all the way but the pipe still seems to vibrate and i can move it with my hand, would it be because ive only got 1 spring or do i need to put rubber bits inbetween the bracket and pipe or is this just normal?
Not too sure if 59's have 1 or 2 springs. My 55 had 2. Yeah you might need some rubber "gromits" I think they're called?? Not too sure. But I wouldn't do it up too tight mate. Or you'll end joining me and Kieran...... Snappy snap snap.
Deffo 2 springs matey, wait for someone to tell you what you need for the bracket as you don't want that wrong.
lol nah ill be alright i told it the other day not to snap coz if it duz i will jus shank it n ting init coz man dnt business, ive gotrubber things behind the bits where it bolts to the engineside but it wobbles from the back bit of the bracket where i cant tighten up the bolt all the way and theres a little gap
I bought mine direct from PM and had all the correct fitments and it didn't move an inch. Snapped after a year n a half, welded up fine though. Should be fine though as you have had a word with it :wtf:
LOOLMYPMBIFTYNINEGOESSOISOISOISOIWOBBLEWOBBLEWOBBLEPLEASEDONTSTABMEIPROMISEIWONTSNAPDINDINGSTARSANDTING.. but back to the point, when terro gave it to me he said heres 'the spring' which i took to mean there was only one spring being used and my maloooosi pipe was only using one spring and it was fine.. would any one of you good sirs be kind enough to give me the adress of that cbs place in whitton or twickenham or take me there *cough typh70 cough*
it def is ment to have to mine does. do you ave all the rite spacers ect. for the bracket as it could be that mine has a couple of diffrent types on an doesnt move at all.
didnt come with any spacers just pipe, stub and spring.. could u take a pic of yours so i can see how its ment to be
Spacers? Out of the 3 PM's i've had about the place none has spacers. It was mounted with only one spring when it was fitted to my mates bike and i don't think it was blowing. Saying that though i mount mine with 4 cut down springs. :rofl:
yer u need 2 spring . 2 washers u need 2 put awasher on the nut that come out ov your pm that goes into the bracket at da back .
its the springs... there too soft from pm.. use 2 tight springs and hope you havent deformed the stub sleeve as it will need cutting off and a new section putting back in.
the spring i got from pm wen i brought my pipe are as tight as can be and i put them in with the tool
erm.. pm springs suck, thats why they all snap at the front.. or used to befor they doubled up the metal and the tool? best ive ever found is a good pair of pliers
i managed to get it tight and not wobbling.. bought some rubber gromets from halfords and put them behind the bracket bolts.. sorted
i myt be going cbs on saturdee jamel if your lot wanna come down. might get a 21mm for the ziperdeeelonggerwheeliee thign.
