pm 59 dent
Discussion in 'The Workshop' started by jj180, Dec 1, 2007.
  1. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    ive got a tiny dent on my 59 from my off but is there any chance i could get it fixed atall so i can get it chromed atall although yes i know it will be hard as ive used it
  2. abz
    abz Member
    there is away take it to a body shop they can weild a lil metal bit to it then pull it out then cut it off an grind it flat, also u cant chrome it now as its been used
  3. StEvO
    StEvO Active Member
    speak to terro, he has his dent sorted properly
  4. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    ive been told you can as someone on ere has but takes alot longers and it must be prepared for weeks
  5. tErr0
    Yes you can get the dent removed if you have a body shop good enough or willing to do it. Took me a while to find one that did.
    They weld rods on and pull them out with a slide hammer as you can't get to the back of the dent. This will pull out the dent so it will remove any lost performance but it wont look like new.
    You could chrome it even after it has been used if you can find somewhere that will do it. *James* off here had it done but i can never remember where he said he got it done. It did take ages as the had to soak it for weeks to get all the crap out.
    Buuut when chroming they first polish the thing then chrome over the polishing and you will not be able to get a nice flat finish where the dent was... You may have a slight chance but you will remove so much material you could go through the metal.
    I can't quite remember how much i got the dent pulled on my exhaust for but it was something cheap like £10-20.
  6. StEvO
    StEvO Active Member
    im sure james place wernt aware that the pipe was used and it took them over a month, said they would never do that again?
  7. shiny red
    shiny red New Member
    i could get the dent out for ya no problem ,but i live in gloucestershire if you want to bring it here its a 10 min job bit far i think though.any welding shop can do it.as for chroming you got no chance if its used?you can fill it with caustic soda evil shit mind and leave it for a week then wash it out but the quailty of chroming will be crap :(
  8. alexsr70
    alexsr70 New Member
    i dented the expansion chamber on my rm125, and my dads mate heated it up and blew hot air through whilst bunging one end. the dent smoothed out but as terro said it wasnt perfect, can this not be done? because it didn't leave any weld marks
  9. Haresign
    Haresign New Member
    GPR50 + Peugeot 307
    The caustic soda instructions say to leave it in for 30 mins, isn't a week a bit too long??
  10. MiNoR cOnFuSiOn
    wont be a pipe left.. need an ultrasonic cleaning tank. there fucking ace but well expensive to do pipes as theres so much shit in there. why chrome a pipe your gonna have to weld once a year?
  11. shiny red
    its called sarcasm i was trying to show how hard it would be to clean it out? and good luck on finding some one to put it in their ultrasonic tank i would not put it mine(works) and do not know any one who would? :D
  12. MiNoR cOnFuSiOn
    i would, in a rubble bag full of deonised water and washing powder... works wonders an the tank stays clean ;)
  13. jj180
    jj180 Active Member
    Mrt 183/Vespa 300
    its the reinforced version havent had no problems what so ever
