pm 55mm
Discussion in 'Scooter Tuning' started by Edgar, Apr 12, 2012.
  1. Edgar
    Edgar Active Member
    can tell if its pm 55mm cranks just by looking at it when crank is in cases ??
  2. ramo
    ramo GoldMember
    Not unless you've got the eyes of a hawk or similar tbh it's hard enough to tell with no cases involved. Of you're planning to buy a 183 or something like that check for the spacer instead
  3. Jonnymarrw00t
    Piaggio Zip 05 plate
    get a micro meter measure the length of the conrod ?
  4. Edgar
    Edgar Active Member
    there was like alot of gaskets instead of spacer so i took them out and it hits a head now so im guessing it is a 55 one as seller stated ,
    does any one know what size spacer do i need for that crank ? im running malossi kit on that if it helps
  5. Jonnymarrw00t
    Thought you said 172's 183's use to much fuel ;)
  6. Edgar
    Edgar Active Member
    got a bargin , a 183 and 172 bike for a grand :p
  7. tErr0
    Use the search? Been covered a lot of times. If it's been bodged so much it doesn't have the right spacer I expect port correction hasn't been done.
  8. Edgar
    Edgar Active Member
    cylinder and case ports match as far as i can see, and there is some flow done aswell
  9. Edgar
    Edgar Active Member
    is it 1.5 one ? just to make sure
