Piston Rings
Discussion in 'The Workshop' started by Princey, Nov 15, 2011.
  1. Princey
    Princey New Member
    1992 Yamaha SR125cc
    My Suzuki Ap50, is now making a rattling noise and is losing power (Again)
    I think its a piston ring, anyone know how hard it is to change it, and are they expensive
    Or if this is even the problem?
    Thanks :p
  2. Chubz
    Chubz Well-Known Member
    70cc Aerox 04'
    if it is the piston rings, they arnt that exensive mate, maximum say around 20 quid. they are usually pretty easy to fit too.
    also you checked if youre exhaust is on nice n tight ?
  3. xplicit vehicle
    xplicit vehicle Member
    PGO Big Max 50
    u "think".. atleast make sure it is.. could be something where u dont need to spend any money at all
  4. 2T-Customs
    2T-Customs New Member
    Aprilia SR50's
    Best way to check rings is to do a compression test on your cylinder. If the PSI is good and hold, then the rings are fine and the rattling is somewhere else.
    Typically if you have rattling, and the scooter starts, then it isn't the rings because in order for the rings to be worn enough to allow the piston to slap the side of the cylinder, you will essencially soft sieze your motor. The thing wouldn't even start. My guess is the rattling is coming from somewhere else. But always good to do a compression test and verify.
