Piston renew
Discussion in 'General Tuning' started by Makaveli123, Oct 9, 2011.
  1. Makaveli123
    Makaveli123 GHOST RIDER
    Aprilia RS50 2004
    Are there any benefits in renewing a piston and rings? My bike is quite old but still in running order, and i was wondering if a new piston and rings will help with anything...
  2. Jonnymarrw00t
    Piaggio Zip 05 plate
    Well is the piston scored ? No point if it isn't.
  3. TuningMatters
    TuningMatters New Member
    Gilera Runner
    Actually not true. Using a new piston (especially a bigger one) and new rings will help you increasing the compression back to original again.
    Pistons are available in different sizes usually marked with an A-D. Since your cylinder walls are wearing off you loose compression which instantly results in a loss of power.
    Make sure when replacing the piston to also replace any blankets with new ones.
    Best,
    D
  4. Jonnymarrw00t
    Why would you fit a over sized piston on a kit when it hasn't been bored out ?
  5. tErr0
    It's not an over sized piston it's just a slightly larger one. Your bore and piston both wear down very small amounts over time so normally not only do you have to fit a new piston eventually as it's not really fitting properly but you also need to fit a slightly bigger one.
  6. Jonnymarrw00t
    Oh right, Thank-you for clearing that up :')
  7. stkflote
    stkflote Member
    zip 2t cat
    i bet it wont fit with out a rebore, ive tried it in the past ,
    ive filed piston rings down before
  8. m1tch
    m1tch Member
    The Blata B1 LC engines when ordering a new cylinder or piston have different sized pistons A, B or C, its the same displacement, but they are all slightly different much like matching barrels and cases etc the correct combination will give the best performance.
  9. FLENG2008
    FLENG2008 Member
    04 vx 125
    did you really file down a piston ring?
    lool
  10. m1tch
    m1tch Member
    Erm, you need to check the ring gap clearance before installing a piston ring, you might need to file the ring down slightly to ensure that the correct gap is there.
  11. stkflote
    stkflote Member
    zip 2t cat
    yes used to do it a lot,it was a done thing,you had to be very careful
    and i used small rifler files,
    You dont do it on two strokes that have pins in piston lands
