Piston Dented and Bore Dented
Discussion in 'The Workshop' started by Duggiedan, Apr 19, 2012.
  1. Duggiedan
    Duggiedan Piaggio zip 50cc
    Piaggio Zip
    Hey guys, as if you read my other thread i was riding along and my scooter cut out on me and sounded like theyre was no compression, eventually ive stripped it done and noticed a nice chunk out of piston and dented bore, i know i need to replace this but would this of caused it to cut out?
  2. CA Zip tuning
    CA Zip tuning Member
    wheres your other thread ?
  3. Duggiedan
    Piaggio Zip
    Workshop.
  4. roxy boy
    roxy boy Well-Known Member
    roxi
    it can be caused by running the bike lean and over heating of the piston too fast ...
  5. Duggiedan
    Piaggio Zip
    it isnt running lean tho ? :confused:
    Its running slightly rich
  6. roxy boy
    roxi
    did you let the bike warm up b4 raggin it ...an also has it been run in
  7. Mr Bizzle
    Mr Bizzle Active Member
    04 Aerox 70 stage 6
    Had the tip come off the sparkplug or part of a ring broken off? cos it usually takes a foreign object to cause this.
  8. Duggiedan
    Piaggio Zip
    yee callum i have to or wont move :p spark plugs in 1 piece and aint check ring or circlips
  9. Stathis
    Nrg Power 70cc
    wait what just happen?? the 50cc broke on you??? o_O they are not likely to fuck up...
  10. Duggiedan
    Piaggio Zip
    nope Athena 70cc Kit on and barrel n pistons fucked, i know i need to replace it will do wen i start new job next week but i want to know if this caused my bike to cut out n not start :confused:
  11. roxy boy
    roxi
    yes of coarse it will make it not start...and the onlt things i know that will corse sumet like that is running lean and heating the piston up 2 fast and just normal wear but it will take a lot off full throttle miles to do that
  12. Duggiedan
    Piaggio Zip
    i aint checked the circlip but the piston seemed wobbly so that might of come out and got caught n scored barrel
  13. roxy boy
    roxi
    it will be wobbly ...they are as there is a couple of mm gap on either side of the smaal end bearing ..and yes a circlip would do that but unlikely it has only jus come out
  14. Stathis
    Nrg Power 70cc
    maybe Athena isnt just a good brand? and reliable?
  15. Duggiedan
    Piaggio Zip
    when i went to donotlink pedstop i was talking to guy and the athena 70s is one of best kits for a/c bikes better than polini and they are becoming more popular and was running great until then had ace power.
  16. roxy boy
    roxi
    athena is basicly stage 6 ...its the same thing with a different name and the piston is slightly different
  17. Stathis
    Nrg Power 70cc
    cant be man... there is no reason to make two same things with different names.. stage 6 is more popular.. and from what everyone says its more reliable, powerfull ect... i think that what you say its foolish... why wouldnt anyone make 70cc scoots with athena kits then??
  18. roxy boy
    roxi
    athena has made alot of the stage 6 cylinders ...like the modular is exactly the same but stage 6 have kinda bullet shaped piston and athena ha jus a flat piston
  19. Stathis
    Nrg Power 70cc
    then why pedparts show on their diagram that stage 6 is the best??? o_O
  20. roxy boy
    roxi
    becos they havent made all of the cylinders just some of them
